rear arch panel wanted
Post by Ryan 95 on Tue Aug 19, 2014 1:57 pm
is their any suppliers where i can get a rear quarter/arch panel for my Hi-jet?? managed to weld the left side without a problem but the right arch is too far gone Sad
Ryan 95
Re: rear arch panel wanted
Post by HighlyJetted on Tue Aug 19, 2014 2:18 pm
Not that I know of, I just make my own.
Post by Ryan 95 on Tue Aug 19, 2014 2:46 pm
HighlyJetted wrote:Not that I know of, I just make my own.
what, the entire wheel arch?
Ryan 95
Template for wheel arch
Post by doug100 on Tue Aug 19, 2014 3:25 pm
I just welded my arches. One was pretty shot but I made paper templates on the good side and just reversed the paper onto sheet metal for the other side.
Last edited by doug100 on Tue Aug 19, 2014 3:26 pm; edited 1 time in total (Reason for editing : trying to add pic)
doug100
Post by Ryan 95 on Tue Aug 19, 2014 4:13 pm
I'll upload pics Smile
Ryan 95
Post by Ryan 95 on Tue Aug 19, 2014 4:23 pm
Ryan 95
Post by HighlyJetted on Tue Aug 19, 2014 4:46 pm
Get cutting and folding mate! That's a pretty typical rear weld up job.
Done one that the whole arch needing doing front to back.
Start by cutting everything rotten away. Then you can see what you need to fabricate.
Post by HighlyJetted on Tue Aug 19, 2014 4:49 pm
Just make sure this van is worth fixing - rotters tend to also need:-
Rear brake pipework replacing
Leaking Fuel Tanks
Coolant system issues
Rotten front arms
Rotten below the seat belt mounting point on the passenger side - every time.
When an overheating van turns up with its arches hanging out, I always warn the owner its going to cost wayyy more to fix than the van is actually worth.
Post by Ryan 95 on Tue Aug 19, 2014 4:57 pm
HighlyJetted wrote:Get cutting and folding mate! That's a pretty typical rear weld up job.
ok, time to get some cutting disks lol was it a hard job to make your own arches?
Ryan 95
Post by HighlyJetted on Tue Aug 19, 2014 5:11 pm
Time consuming and awkward is probably the best description.
I did away with the under fold arch lip.
Post by doug100 on Tue Aug 19, 2014 9:31 pm
I welded past the under arch fold like Highlyjetted did. Its making the and shaping the metal replacements that takes the time. I found hammering over some steel pipe and then spot welding the ends worked well before welding all in place.
doug100
Post by doug100 on Tue Aug 19, 2014 9:44 pm
I made the inner arch in 5 sections and overlapped them rather than trying to make one piece. You can see the section marks on on the outside in the close up.
doug100
Post by Ryan 95 on Thu Aug 21, 2014 12:40 pm
looks like that's what i'll have to do then
Ryan 95
