Daihatsu hijet 1300 16 valve EFI dual fuel starting problems ..
Post by peekatu on Mon Aug 25, 2014 2:49 pm
Hello I am new to this forum and was wondering if anyone can help ? I have a Daihatsu hijet dual fuel 1300 16 valve EFI 2003 van that has started to play up. It has a problem starting , the engine turns but nothing then after a while I hear a noise at the back of the van like something is kicking in then it starts. Could it be the automatic choke not kicking in ?. If anyone can help I would appreciate it. After it starts I don't have a problem starting it the rest of the day until the following day when the engine has been left idle overnight.
Thanks in advance..
peekatu
Re: Daihatsu hijet 1300 16 valve EFI dual fuel starting problems ..
Post by HighlyJetted on Mon Aug 25, 2014 5:50 pm
I bet that "something kicking in" at the back is your fuel pump.
What is the behaviour of the engine warning light during these starting issues.
Post by peekatu on Tue Aug 26, 2014 7:26 am
Hi the engine warning light stays on also the fuel gauge works intermittently.
peekatu
Post by HighlyJetted on Tue Aug 26, 2014 8:10 am
When you turn the ignition on do you hear the fuel pump kick in?
Post by peekatu on Tue Aug 26, 2014 8:31 am
No ..
peekatu
Post by peekatu on Tue Aug 26, 2014 8:47 am
after a while you can hear it kicking in
peekatu
Post by peekatu on Wed Aug 27, 2014 8:35 am
Thanks everyone , I fixed it myself Laughing
peekatu
Post by jamesgates1000 on Wed Aug 27, 2014 9:42 am
What was the problem? What do you do to fix it?
jamesgates1000
