Help!!! Wiring ID and a chopped off hose
Post by Stuntman on Wed Aug 27, 2014 6:08 pm
Hello chaps,
Help needed! The po has bodged the fan to be always on, using methods a teenage boy racer from the 90's would be proud off.
He's also chopped off a hose and shoved a bolt in to stop the end of it.
Can anyone help please guys, oh and I've set fire to dash, I need to rip it out and see if there are any more bodges behind the panels, grrrr!!!
Stuntman
Re: Help!!! Wiring ID and a chopped off hose
Post by Stuntman on Wed Aug 27, 2014 6:09 pm
<a href="http://illiweb.com/fa/pbucket.gif" target="_blank"><img src="http://illiweb.com/fa/pbucket.gif" border="0" alt=" photo imagejpg1-2.jpg"/></a>
Should thus be plugged into anything?
Stuntman
Post by Stuntman on Wed Aug 27, 2014 6:12 pm
Stuntman
Post by Stuntman on Wed Aug 27, 2014 6:13 pm
Stuntman
Post by Logi on Wed Aug 27, 2014 6:17 pm
The fan relay is supposed to live around there, they have a tendency to bugger up. The hose is your bleed valve.
Post by Stuntman on Wed Aug 27, 2014 6:21 pm
I take it that it should not have a bolt in the end then, more of a valve. The multi plug that is there has 4 connections, I take it it should plug into something?
Stuntman
Post by FrontBackSide2Side on Wed Aug 27, 2014 7:04 pm
No valve as such, it's usually just a little rubber cap. Chances are it got lost as some point and replaced with that length of hose.
Is yours a dual fuel model or has it ever been?
Post by Stuntman on Wed Aug 27, 2014 7:26 pm
I don't think so, there is no filler cap or tank fbsts.
I'm happy to bypass this entirely with a kenlow and a thermostat, but I'd like to get this identified first Smile
Stuntman
Post by Eightpot on Wed Aug 27, 2014 7:36 pm
It should look something like this:
You can pick them up on ebay for much cheapness. If you do replace that length of hose, don't chuck it out as it is halfway to being a pressure tester - all you need is a schrader valve (car tyre) and a compressor.
Eightpot
Post by Stuntman on Wed Aug 27, 2014 7:41 pm
Cool, stupid request but you don't have a link to one eBay do you? Thanks chaps
Stuntman
Post by Eightpot on Wed Aug 27, 2014 7:53 pm
Eightpot
Post by Logi on Wed Aug 27, 2014 8:14 pm
Stuntman wrote:I'm happy to bypass this entirely with a kenlow and a thermostat, but I'd like to get this identified first Smile
scratch
Logi wrote:The fan relay is supposed to live around there,
cheers
Post by Stuntman on Wed Aug 27, 2014 9:09 pm
Ace thanks dudes
Stuntman
Post by HighlyJetted on Thu Aug 28, 2014 12:04 am
I just use a bit of pipe with a bolt in it like what you've got.
Except I cut the head off and make it look respectable.
Post by HighlyJetted on Thu Aug 28, 2014 12:05 am
Also all I'm going to say from previous experience with alot of hijets -
Dodgy fan wiring.
Altered Bleed bung.
99.9% needs a head job and other stuff.
