Hazards keep blowing relays -fixed
Post by Stuntman on Thu Aug 28, 2014 2:29 pm
Hello guys
I have never tried to the hazards but when I do they keep blowing relays, and to be honest the comedy is wearing thin!
Is there a common problem with these?
Or where would the earth for these be?
Thanks guys
Stuntman
Re: Hazards keep blowing relays -fixed
Post by HighlyJetted on Thu Aug 28, 2014 7:19 pm
Didn't think there was a hazard relay, thought there is just an indicator relay.
Post by Stuntman on Thu Aug 28, 2014 8:04 pm
True, my mistake. I was busy lobbing tools in the barn
Stuntman
Post by HighlyJetted on Thu Aug 28, 2014 8:21 pm
Do the indicators work? Every bulb?
Post by Stuntman on Thu Aug 28, 2014 8:39 pm
Yep, every bulb, I've checked the connections for fraying but couldn't find any, I'm looking at removing the circuit from the loom by creating a separate bypass loom but I need to know the wiring circuit first.
Hj any knowledge of the loom?
Thanks in advance
Stuntman
Post by HighlyJetted on Thu Aug 28, 2014 9:20 pm
Look at the hazard warning indicator lamp.
It is a very simple system.
The hazard switch itself is probably buggered. Stalks are prone to going a bit grim!
Post by Stuntman on Fri Aug 29, 2014 9:33 pm
Well, after chopping out the entire lhs indicator wiring loom and replacing it, I now have operational indicators and hazards, what a complete ball ache
Stuntman
Forgot to say, thanks guys
Stuntman
Post by FrontBackSide2Side on Fri Aug 29, 2014 9:52 pm
Did you find any faults whilst you were ripping it out?
Post by Stuntman on Fri Aug 29, 2014 10:01 pm
Not physically, but I tested the wires by bypassing each indicator in turn, I think the main problem was with the rear lamp, I replaced the whole lot from the stalk to each lamp, I'm thinking possibly damaged wiring in the body to the rear lights.
Stuntman
