daihatsu hijet efi 16 valve 2003 does it have a distributor cap ?
Post by peekatu on Fri Sep 05, 2014 2:27 pm
Hello , Can you tell me if daihatsu hijet efi 16 valve has a distributor cap ? Embarassed
peekatu
Re: daihatsu hijet efi 16 valve 2003 does it have a distributor cap ?
Post by Eightpot on Fri Sep 05, 2014 3:48 pm
If it's like my 2003 it doesn't have a distributor, leave alone a cap. Check on the rocker cover and you should see four coil packs, each one directly above its sparkplug.
Eightpot
Post by peekatu on Fri Sep 05, 2014 5:24 pm
Thanks i will do that .. Do they ever need replacing ?
peekatu
Post by FrontBackSide2Side on Fri Sep 05, 2014 9:36 pm
No they don't have a dizzy, they have a camshaft sensor instead. And yeah sometimes the coilpacks go faulty and sometimes the tube that goes from the coilpack to the sparkplug goes faulty too.
Post by peekatu on Sat Sep 06, 2014 7:25 am
Are they expensive to change ?
peekatu
Post by HighlyJetted on Sat Sep 06, 2014 10:20 am
Well you only change one when you prove it doesn't work, by using a process of elimination.
Post by peekatu on Tue Sep 09, 2014 12:15 pm
I think it's the fuel pump , if I don't hear it kicking in then the engine won't start even on LPG . Does the fuel pump effect LPG in starting the engine even if it's not on the petrol mode?
peekatu
Post by HighlyJetted on Tue Sep 09, 2014 12:27 pm
Two small wires that go to the batter live terminal are broken some where.
Post by peekatu on Tue Sep 09, 2014 12:55 pm
Thanks ,the engine still turns over if that makes any difference also the petrol fuel gauge works intermittently .
peekatu
Post by HighlyJetted on Tue Sep 09, 2014 5:53 pm
Does the engine warning light come on when you turn the key to On?
Post by peekatu on Tue Sep 09, 2014 6:41 pm
HighlyJetted wrote:Does the engine warning light come on when you turn the key to On?
Yes before i start the van  but not when the engine is turning over ,it goes off
peekatu
Post by HighlyJetted on Tue Sep 09, 2014 8:03 pm
Can you hear the fuel pump running when you turn the key?
Post by peekatu on Wed Sep 10, 2014 8:45 pm
HighlyJetted wrote:Can you hear the fuel pump running when you turn the key?
yes it runs intermittently
peekatu
Post by HighlyJetted on Wed Sep 10, 2014 9:40 pm
It should run for about 3 seconds when you turn the key on.
If you put your ear to the end of a long screw driver and touch the end against an injector, can you hear it ticking?
Post by Guest on Thu Sep 11, 2014 5:38 am
Earlier four cylinder model between 1998 and 2001/2 had only TWO coil packs. They are pretty easy to remove the coil packs. The two coil pack models had two 10mm nuts holding them on whereas the four coilpack ones have only one 10mm nut holding them on.
And yes they do pack up occassionly. I have sold three of them in the last month. You wouldnt want to buy new ones. If you need ANY spares for Hi-Jets try HJ or me before asking anywhere else.
Post by peekatu on Tue Sep 16, 2014 6:46 pm
*****update******
thanks everyone for your help I did think it was the fuel pump at one point because it would come on intermittently when I turned the ignition key, I also noticed that when I charged the battery up after running the battery down trying to start the engine the fuel pump would kick in and start the engine.So I decided to upgrade the battery to a more powerful one and now so far it starts first time Very Happy
peekatu
