steering wheel removal
Post by Ryan 95 on Sun Sep 14, 2014 8:12 pm
how the hell do they come off? i've removed the horn push, and the nut is loose, but i cant seem to get the wheel off, i've pushed, pulled, jiggled and hit it with a hammer but the steering wheel is really stuck on that column, so lost my temper and gave up for the night:oops: Mad Mad Mad Mad
any ideas?
Ryan 95
Re: steering wheel removal
Post by d1noh on Sun Sep 14, 2014 9:22 pm
Undo the nut a few mm, get your nees under side of wheel and push up while hitting the nut with a dead blow hammer
Post by Ryan 95 on Sun Sep 14, 2014 9:39 pm
d1noh wrote:Undo the nut a few mm, get your nees under side of wheel and push up while hitting the nut with a dead blow hammer
that's what i done, soaked the shaft in WD 40, hopefully it'll penetrate over night and loosen the rust taper Wink
Ryan 95
Post by scotia on Mon Sep 15, 2014 7:46 am
and if you can dont remove the big nut completely
let it on a litle bit of thread if theres room.
so you always have sort of a security that you will not bust your teeth out when it finily comes loose.
you can remove the nut when the wheel is loose enough
Post by FrontBackSide2Side on Mon Sep 15, 2014 10:31 am
I find using a rocking motion works well. Pull one side of the wheel then the other, do that a few times then swap to pulling the top and bottom of the wheel and repeat.
Post by Ryan 95 on Mon Sep 15, 2014 1:01 pm
Sorted, soaked it in WD 40 overnight, and it finally came of with a lot of pulling and bashing with a hammer! Very Happy
Ryan 95
Post by Cromwelluk on Sun May 31, 2015 10:33 am
Hi I'll second the rocking technique , tried the mallet an brute force , a quick google and " rocked" the steering wheel, grab it at 12 & 6 o'clock and then at 3 & 9 push and pull on opposite side followed by a quick pull  and it popped off and yes leave the nut on a few turns  Simples I was amazed how easy it was
Cromwelluk
