imoberliser problem
imoberliser problem
Post by DonnyMacdonald on Mon Sep 15, 2014 10:50 am
HI Guys I have a problem with my panel van it woant start that is to say nothing dead as a dodo now I have had an aoto electrician look at it and he informs me it is the ECU imoberliser not allowing any spark or fuel to the engine,I have phoned around otherexperts who inform me that I need fault codes to se were the trouble is or it could be in the wireing, its an 08 plate and I would like to fix and sell it so any help or advice would be much appriciated donny
DonnyMacdonald
Re: imoberliser problem
Post by HighlyJetted on Mon Sep 15, 2014 6:51 pm
Didn't think there was any kind of immobilizer on them, but I have never seen one on a 2008 plate.
Does it even turn over on the key?
Post by PFM on Tue Sep 16, 2014 3:14 pm
No immobilizer on my '08 Porter. Did the 'auto electrician' not manage to find the fault codes?
Post by DonnyMacdonald on Wed Sep 17, 2014 11:58 am
Hi Guys
the imoberlise was instaled by the company who converted the van (now gone bust )the van does not start or fire up from the key it did befor just after the new engine was put in ,the auto electricion did'nt mention the codes and by the way he did'nt come back after his first visit.
DonnyMacdonald
Post by FrontBackSide2Side on Thu Sep 18, 2014 12:17 pm
When you say "converted" what do you mean? LPG? camper conversion? etc
If you are sure it is the immobilser i would remove it. Other than that, find out what make and model the immobilser (should be a label of some sort on the unit itself or do you have any paperwork?) and contact the manufacturer to see if they can help.
Post by DonnyMacdonald on Sat Sep 20, 2014 1:39 pm
It was converted into a sandwich van with an oven and fridge I had 4 vans doing the rounds but unfortunatly I became ill and had to sell out the buisness I keep one van now for events etc ,good idea I will check the manufacturer and see if that helps,I don't understand why its just not working
DonnyMacdonald
Post by FrontBackSide2Side on Sat Sep 20, 2014 3:31 pm
It's not uncommon for aftermarket immobilisers to go faulty to be honest.
Last edited by FrontBackSide2Side on Sat Sep 20, 2014 9:14 pm; edited 1 time in total (Reason for editing : terrible spelling)
Post by DonnyMacdonald on Sat Sep 20, 2014 3:44 pm
Do you think it would be posible to remove it and get the engine runing again or will it have to be decoded sort of
DonnyMacdonald
Post by d1noh on Sat Sep 20, 2014 6:19 pm
they normally just cut and splice into the loom by the starter key, cut it all out and re join the wires, simple
Post by FrontBackSide2Side on Sat Sep 20, 2014 9:19 pm
^ This
You will probaly have to unwrap the wiring loom in places to find out exactly what has been spliced or interupted etc but once you can see where all the joins are it should be self explanatry as the wires are colour coded so it will just be a case of rejoining the red wire to the red wire and the blue wire to the blue wire for example. Anything that has been spliced in can obviously be cut out.
Post by DonnyMacdonald on Sun Sep 21, 2014 1:56 pm
Thanks guys for all the info I will keep you posted on the progress and the outcome ,thanks again .
DonnyMacdonald
