Engine swops
Page 2 of 2 Previous  1, 2
Re: Engine swops
Post by rich the mechanic on Fri Mar 01, 2013 8:01 pm
HighlyJetted wrote:The rears could be ok another 50mm diameter. The front on the other hand will want to shred themselves against the corner of the doors when the van leans over a little while cornering.
fitting the LSD will elimiate the body roll as you will be able to get the back sliding everytime and keep the body upright Very Happy Very Happy Very Happy
Re: Engine swops
Post by xxemaphorr on Fri Mar 01, 2013 8:06 pm
bump stops + wheel spacers + body chopping + low profile tires and im close! lol
xxemaphorr
Re: Engine swops
Post by HighlyJetted on Fri Mar 01, 2013 8:20 pm
I like riches approach!!! There are times though when mounting kerbs, doing turns in the road, driving round tight dog legs etc.
I think you'll find spacers will only make the bottom of the door collision worse. Think about how the wheel turns around the strut when you steer, pad it out more and it swings with an even wider curve.
This is the collision point!
Re: Engine swops
Post by xxemaphorr on Fri Mar 01, 2013 8:26 pm
spacers were necessary to fit the wheels, as were the extended wheel studs. i dont profess perfection, but chasing the dream sure is fun!
xxemaphorr
Re: Engine swops
Post by Logi on Fri Mar 01, 2013 8:47 pm
HighlyJetted wrote:I like riches approach!!! There are times though when mounting kerbs, doing turns in the road, driving round tight dog legs etc.
Watch out you don't get a puncure, that nail looks iffy Wink
Re: Engine swops
Post by HighlyJetted on Fri Mar 01, 2013 9:00 pm
As my Dad says "that's a puncture waiting to happen" - know it all bastard
Anyway it looks more like a Drywall screw.
In my world they are everywhere, when I open the doors in my van they fall out of the gap, and as my drive is gravel the just vanish unit they get kindly collected by a tyre!
Re: Engine swops
Post by rich the mechanic on Fri Mar 01, 2013 9:07 pm
There is space there just trim the door back and weld the two edges together then loads of clearance.
Re: Engine swops
Post by HighlyJetted on Fri Mar 01, 2013 9:26 pm
Then there is the folded seam of the inner wing that needs something doing with it.
Re: Engine swops
Post by rich the mechanic on Fri Mar 01, 2013 9:34 pm
roll it out or up where there is a will there is a way.
Re: Engine swops
Post by xxemaphorr on Sat Mar 02, 2013 9:52 am
up until recently I thought I was the only one mad enough to tinker with Hijets! I will persevere and maybe, just maybe, I'll get there!
xxemaphorr
Re: Engine swops
