water dripping from the exhaust
Post by peekatu on Sun Sep 28, 2014 12:04 pm
Hi , I have a daihatsu hijet 2003 efi duel fuel van . It over heated today on a short trip when i let it cool down i topped up the radiator with water and anti freeze, let it run again looked for leaks waited for the fan to kick in . Then found there was water dripping from the exhaust what could that be ? ..I checked it when it was running and the exhaust was dry but after the fan kicked in it was dripping . I smelt the water to see if i could smell anti freeze but couldn't ANY IDEAS ?
peekatu
Re: water dripping from the exhaust
Post by peekatu on Sun Sep 28, 2014 2:50 pm
I had a look on YouTube Found a vid , said give this a try first K-Seal Permanent Coolant Leak Repair, Head Gaskets & Radiators by Kalimex K5501 worth a try i guess Smile
peekatu
Post by Eightpot on Sun Sep 28, 2014 7:48 pm
Personally, I wouldn't bother with the K-seal.  It might work (I tried it in a Rover V8 once, didn't work...) or it might well block up your rad.  You might want to watch this video before you add the stuff to the coolant:
Eightpot
Post by peekatu on Wed Oct 01, 2014 11:52 am
Eightpot wrote:Personally, I wouldn't bother with the K-seal.  It might work (I tried it in a Rover V8 once, didn't work...) or it might well block up your rad.  You might want to watch this video before you add the stuff to the coolant:
Hi thanks for the advise ... I used k seal before and it worked so i give it another try and it seems to have done the trick Smile
peekatu
Post by HighlyJetted on Wed Oct 01, 2014 1:35 pm
Every exhaust emits water, that is why they rust so bad.
