I am now stocking radiators, fuel caps, thermostats and radiator caps!
Post by HighlyJetted on Thu Oct 02, 2014 2:00 pm
Title says it all really...
Fuel Caps http://www.ebay.co.uk/itm/171482353947?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Radiators http://www.ebay.co.uk/itm/171482276291?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Radiator caps and Thermostats are here, but not listed yet.
You can find my contact details here http://www.autofaultfinder.com/
Re: I am now stocking radiators, fuel caps, thermostats and radiator caps!
Post by derekmwalshaw on Fri Oct 17, 2014 5:30 pm
Hi quick question. Where can I get engine temp. gauge sender unit from please? The one that's on the engine block.
Cheers Derek
derekmwalshaw
Post by HighlyJetted on Fri Oct 17, 2014 5:58 pm
1.3 or 993cc?
I have got a couple of 1.3 ones.
You can get my contact details on http://www.autofaultfinder.com
Post by derekmwalshaw on Fri Oct 17, 2014 6:55 pm
Oooops! forgot to say which van. Its for a 1997 1.0L EFI Hi-jet bus. Reason is, that the cooling fan kicks in when the temp gauge showing various readings. From under half way to nearly on red. I'm not whether this is normal or not? Any help appreciated
Cheers Derek
derekmwalshaw
Post by PFM on Fri Oct 17, 2014 6:57 pm
Well done, good luck with that side of your enterprize. You're the 'cooling dude'! (Could we have the cool santa emoticon - or even some other xmassy ones for a while?)
Mattsbitsforsale - sounds a bit like the missus has done a hatchet job!
Post by HighlyJetted on Fri Oct 17, 2014 8:52 pm
I should change it to rent!
Post by Stevem on Sun Dec 27, 2015 7:00 pm
Have you any filler caps left, could do with one after local yobs busted mine to steal petrol from my Porter pickup
Cheers
Steve
Stevem
Post by Raggy on Sun Dec 27, 2015 8:06 pm
Best just give them a ring (see earlier link for contact details) HJ not a frequent visitor these days. Got one from them the other month. He does them on ebay as well but can never find the link, just as easy and quick giving them a ring.
Hit 1.3 Petrol/LPG 2003 Thermostat
Post by Ednorris1 on Thu Aug 18, 2016 1:13 pm
Hi There would you have a thermostat for my motor?
if so how much are they?
Thanks Very Happy
Ednorris1
Post by PFM on Thu Aug 18, 2016 1:20 pm
I have a small supply of Nipparts thermostats on the way, if HJ is out of stock
Post by Ednorris1 on Thu Aug 18, 2016 1:22 pm
Awesome where can i buy from?
Ednorris1
Post by HighlyJetted on Thu Aug 18, 2016 5:42 pm
I have zero stock, and will not be buying any more.
I do however have 2 Denso radiators in stock at the moment.
Post by PFM on Thu Aug 18, 2016 8:42 pm
Please pm me, ed. Will reply tomorrow
