hijet windscreen removal
Post by johnp on Tue Oct 07, 2014 3:09 pm
Hi there,anyone removed the windscreen from '98 hijet,am I right in thinking there is a removable rubber bead holding the glass in?
johnp
Re: hijet windscreen removal
Post by HighlyJetted on Tue Oct 07, 2014 5:57 pm
Yeah, plenty of lube, put some pressure on the screen from the inside, work the rubber on the outside with a credit card or plastic scraper.
Good luck!
I've got a spare screen in my garage if you can collect.
Post by PFM on Tue Oct 07, 2014 9:45 pm
HighlyJetted wrote:Yeah, plenty of lube, put some pressure on from the inside, work the rubber
Am going to get banned Smile
Post by johnp on Wed Oct 08, 2014 12:34 pm
thanks for that,dont need a windscreen,need to remove to fix rust on frame.
johnp
Post by HighlyJetted on Wed Oct 08, 2014 2:27 pm
Small chips turn into big cracks, so beware!
