Dodgy fuel gauge, looking for a [cheap] second hand unit
Post by small van man on Wed Oct 15, 2014 8:56 pm
Hi all
Am the proud owner of a 1.3 EFI LPG Hijet Van [good times], however the fuel gauge does not seem to work [bad times].
Temp gauge works, can get low fuel light to work, but gauge will not work even when I earth it at the dash.
Just wondered if anyone has got or knows of a replacement instrument panel about anywhere.
Many thanks
small van man
Re: Dodgy fuel gauge, looking for a [cheap] second hand unit
Post by LloydAJN on Fri Oct 28, 2016 1:04 am
Hey,
I have a similar problem, did you manage to get this fixed?
I don't have a low fuel light though, was like this when i bought it, don't think he turned the light off though.
Any help would be amazing.
LloydAJN
Post by Logi on Fri Oct 28, 2016 6:08 am
The sender unit is a tube with a float, the bottom falls off the tube and either the float falls out or sticks because the tube is no longer cylindrical.
Post by LloydAJN on Fri Oct 28, 2016 10:31 am
Cheers logi, I'll fix it when I get a new tank to put on Smile
LloydAJN
