Ignition Barrel and Key
Post by StvC on Sat Oct 18, 2014 8:26 pm
Hi all, back from an exciting time setting up home in Bulgaria and it's time to get my HiJet on the road after it's new paintjob.
However, I stupidly sold another vehicle to a guy in the states and left the keys in==on the key ring of that vehicle and have since been unable to make contact. The key had already snapped off in barrel so now I have a vehicle stuck in a unit at my old work with the steering lock on and no way to move it.
Ideally I need someone to supply and fit said part if at all possible (Matt/Dino...presuming you're both still about?) If not, perhaps Woody or someone else has one...I'm just tight for time before I have to leave UK again.
Failing that....is it a big job to snap the lock and hot wire it for a temp fix?
Steve
StvC
Re: Ignition Barrel and Key
Post by d1noh on Sun Oct 19, 2014 7:02 pm
The key has to be turned to position 1 to retract the barrel so unless anybody wants to correct me the only way is a hammer and chisel on the tamper proof bolts to remove the whole lot, you can then start it with a flat screwdriver
Post by HighlyJetted on Sun Oct 19, 2014 7:15 pm
^^^ what dino said.
You need to take the column plastics off.
Then you will see 2 domed headless bolts, which as Dino said, if you use a nice hammer and chisel then you can undo them by "chasing them round" anticlockwise.
Then unscrew the ignition switch off the ignition barrel assembly, then you can just start with a screw driver, and you won't have a steering lock either.
Post by StvC on Fri Oct 24, 2014 10:54 am
Ah, ok, I'll get hammering then!
StvC
