XR2 pepperpot alloys
Post by dee26173 on Mon Sep 27, 2010 8:59 am
Okay I haven't quite grasped the whole PCD thing with alloys (sorry). Bloke about 80 miles from me is selling these alloys.
I measured centre to centre (opposite studs) which was 4.6 inches. I also measured the shorter measurement from stud to stud which was 3.2 inches?? I emailed the guy and he said from stud to stud on these wheels is 4.5. I really dont want to come across as incredibly thick (which to some I may) but these won't fit right?
I was also told that mini alloys also fit and again spoke to another bloke where he said the measurement was 4 x 101.6 mm. confused
dee26173
Re: XR2 pepperpot alloys
Post by 8bit-ash on Mon Sep 27, 2010 10:37 am
Mini alloys won't fit. Ford alloys will. You will need wobbly nuts which are about £35 a set. You will probably also need to sand the centre bore out a tiny bit. Less than a mm I think.
Wheel PCD is measured usually in mm. Search wheel pcd guide in google and you'll find lists of different wheel pcd's.
Hijets are 4 (4 holes) x 110 (110 mm centre to centre between diagonal holes)
You'll struggle to find this pattern on many other cars hence going for the more common 4 x 108 which can be found on fords, pugs etc. Because theres only 2mm difference you can use the wobbly nuts to get them to sit central.
Post by difflock123 on Wed Oct 06, 2010 5:25 pm
Depending on cost obviously, but most of the alloys in Halfords are multi PCD (108, 110 and 112 PCD)
Just for peoples info Smile
I think I saw a set of 4 alloys with tyres for £350...
I personally am sticking with the standard 12" steels Razz
Mostly because the Hijet will go hopefully before christmas Razz
For a Landy S3 with 16" disco steels with 235/85R16 BF Muds Razz
Post by 8bit-ash on Wed Oct 06, 2010 7:32 pm
the 110 pcds in halfords are probably 5 stud. I very much doubt you'll find a 4 stud 110 multifit
Post by difflock123 on Thu Oct 07, 2010 11:08 am
The ones I saw had 12 stud holes...
They were labelled as multifit 4x108, 4x110 and 4x112.
Might be worth a look.
I didnt pay much attention though, as I wasnt interested for myself....
Post by dee26173 on Fri Oct 08, 2010 4:57 pm
Difflock what size of wheels where they?
dee26173
Post by difflock123 on Fri Oct 08, 2010 5:04 pm
Dont hold me too it, but I think I saw 15, 16 and 17 inch with those PCD's...
They were by the till, thats how I noticed them...
