Head Bolts
Head Bolts
Post by Eightpot on Fri Oct 24, 2014 2:51 pm
My cylinder head is currently in the machine shop being pressure tested for any internal cracks after being found to be un-warped after the little drama n the hard sgoulder of the M3. Phew. But he did raise an eybrow when I told him that as far as I was aware, the engine doesn't use stretch bolts.
Rapid question:
The head bolts. Are they stretch bolts or regular?
Ta in advance.
Eightpot
Re: Head Bolts
Post by xxemaphorr on Fri Oct 24, 2014 4:57 pm
The manual makes no reference to replacing the bolts on strip/rebuild also the diagram doesn't label it as a non-reusable part (or at all even!)
xxemaphorr
Re: Head Bolts
Post by HighlyJetted on Fri Oct 24, 2014 7:38 pm
I always re use them, and I always skim the head as they warp in very funny ways I cant measure, but you can see it as its skimmed pass by pass.
Re: Head Bolts
Post by Eightpot on Sat Oct 25, 2014 3:35 am
Thanks for that. The primary cause of failure on my engine is increasingly looking like the head bolts were insufficiently torqued down followed by a dodgy jubilee clip on the thermostat housing. Need to look at the accuracy of my torque wwrench...
Interestingly, I did notice when putting a staight edge over the deck of the block, that the steel liners stood proud of the aluminium.
Eightpot
Re: Head Bolts
Post by scotia on Sat Oct 25, 2014 7:43 am
daihatsu didnt use strech bolts i heard from a friend of mine who has had several different daihatsu,s.
i know they didnt use them on my current car (hijet) and didnt on my previous (charade GTti).
Re: Head Bolts
