Rear Axle Ratio.
Rear Axle Ratio.
Post by Plasticpig on Sun Nov 23, 2014 3:04 pm
Hi All.
Could someone please tell me what the axle ratio of a petrol engined van would be?
Thanks. Doug
Plasticpig
Re: Rear Axle Ratio.
Post by Guest on Sun Nov 23, 2014 10:05 pm
AAHHHH !!! So you are building a Trike then Doug !! Yes??
Well to answer you question you have a choice probably none of which you will like as the Highest Ratio is pretty low.
They are thus : 993cc 3 cylinder Models up to 1998 are 4.875 to 1
: 1300cc Petrol Models 1998 onwards are 4.444 to 1
: 1200 Diesels are 5.125 to 1
Basically your engine will be revving its heart out ---unless of course you are using a Jap Bike Four Cylinder Engine then I guess that would be great -- giving blistering acceleration.
Post by Plasticpig on Sun Nov 23, 2014 11:05 pm
Woody.
You must be a mind reader.
I have built trikes using both Reliant and Rascal axles in the past, but as they are both getting a bit rare now I thought I would look at Hi jets as there are still a few about.
Thank you for the info. I have several options, but was hoping to use some 17 inch spoked wheels, so I will be doing the maths when I get time.
Thank you.
Cheers.Doug
Plasticpig
Post by Guest on Sun Nov 23, 2014 11:11 pm
I have got plenty of 993 and 1300 axles in stock Doug . cheers bounce
Post by Plasticpig on Mon Nov 24, 2014 12:27 am
Woody.
What sort of prices please. I'm in Cardiff.
Plasticpig
Post by Guest on Mon Nov 24, 2014 6:37 am
The biggest expense is getting it to you. It has to be Palletised which is £45+vat any where in the UK.
Give me a call after 4pm today as I have yet another Funeral to go to this morning.
07863030309 Email address is: hi.jetmaniow@gmail.com 07863030309
Post by FrontBackSide2Side on Tue Nov 25, 2014 4:12 pm
Woody, do you know if it would be possible to swap the axle or diff beteewn 993 and 1300cc models? In other words, i want a 4.875:1 diff on my 1300??
Post by Guest on Tue Nov 25, 2014 4:30 pm
All you need is a complete 993 axle from a PICKUP as shock absorber mounting on the offside shocker on the van is behind the axle.
Whereas on the Pickup Axle both mountings are on the front of the axle.
You could cut the mounting off your axle and weld it on a 993 Van axle but obviously its easier to get a 993 pickup axle. SIMPLES !!!!
Post by Guest on Tue Nov 25, 2014 4:38 pm
Its easier to fit 155x60x12 low profiles as that lowers your ratio by 10% which gives you 4.888-1
straight away without the aggro of changing axles. Also lowers the centre of gravity a bit too.
Post by FrontBackSide2Side on Tue Nov 25, 2014 10:52 pm
ah yeah, sorry i had a blonde moment, i'm after taller ratios not lower ratios Embarassed
Post by Guest on Tue Nov 25, 2014 10:57 pm
Hello again Bimbo,!!! You are out of luck then my friend. 4-444 to is to my knowledge the highest ratio Daihatsu did for the Hi-Jet.
