Door handle frustration
Post by andy pyke on Sun Nov 30, 2014 8:12 pm
I got one of the ebay sliding door handles which I managed to fit. Frustratingly, it didn't work out as I had hoped. After fitting the exterior handle, it just didn't pull the cable that runs inside the door to operate the latch.
Looking more closely at the interior mechanism, it seemed there were two "levers" that were operated by the handle. Only one of them was being operated. It looked like they should kind of work together if the spring would go through the hole for both of them. I tried to do that...and failed. The spring seems to have lost the little post that goes up through the levers and makes them work.
Is it possible to get a little post to fix this (about 2mm tall!) or do I need a whole new interior mechanism?
Picture below...
https://www.facebook.com/photo.php?fbid=10153389121729966&set=a.10153344857584966.1073741834.704249965&type=3&theater
andy pyke
Re: Door handle frustration
Post by FrontBackSide2Side on Mon Dec 01, 2014 6:50 am
i can't see the picture, might be because facebook is blocked on the computer that i am on so i don't really know what this little post is that you are on about but could you use a sellock pin to replace it?
Post by waz on Mon Dec 01, 2014 4:24 pm
Not showing on my computer either
Post by leopard_pagan on Mon Dec 01, 2014 4:42 pm
Privacy settings on the photo need to be set to public
Post by andy pyke on Mon Dec 01, 2014 8:13 pm
andy pyke
Post by andy pyke on Mon Dec 01, 2014 8:15 pm
andy pyke
andy pyke
Post by andy pyke on Mon Dec 01, 2014 8:16 pm
Damn! Got the picture thing working fine before but not any more. Privacy settings are set to public so it should work...
andy pyke
Post by sputnik on Mon Dec 01, 2014 8:36 pm
Piccies are working for me... but sadly I don't know the answer to your problem.
sputnik
Post by andy pyke on Mon Dec 01, 2014 8:59 pm
Smile
andy pyke
Got the picture to work...can anyone suggest a solution?
Post by andy pyke on Thu Dec 04, 2014 8:29 pm
To re-cap, fitted a new sliding door exterior handle. The mechanism didnt pull the cable so I looked on the inside and saw two "levers". One was being pulled by the outside mechanism. There was a spring between it and the other lever (which pulls the door opening cable). It seemed like the pin on the spring should go through the holes in both levers. Whilst trying to do this, I lost the pin.
1. Was I right about the pin going through both levers?
2. Can I get a new pin?
3. Have I ballsed it up completely?
Thanks!
andy pyke
