door dropped
door dropped
Post by BigRon on Fri Dec 05, 2014 9:14 am
Hi, I have aPiaggio Porter van 2005, the drivers door has dropped making it slam into the catch when closing it. the door closes more easily when I lift it slightly but I know if I continue this practice I will be searching for a new handle.
So how do I go about fixing this please any info would be gratefully received. I have a DVD repair manual that I have waded thru but in the Chassis section there appears to be nothing about adjusting the door closing that means owt to me.
I look forward to hearing from you, thanks in advance,
Nigel.
BigRon
Re: door dropped
Post by FrontBackSide2Side on Fri Dec 05, 2014 9:19 am
The hinges are probably worn so i would take a look at those. They may need replacing.
door dropped
Post by BigRon on Fri Dec 05, 2014 9:27 am
thanks for that can you swap over near side and off side hinges. Sorry about the reply I find these forums difficult to use anyway thanks for your help in advance
BigRon
Re: door dropped
Post by HighlyJetted on Fri Dec 05, 2014 10:25 am
It will be the top hinge on the drivers side.
I think you can swap them round.
Just need a 12mm ratchet spanner.
Re: door dropped
Post by BigRon on Fri Dec 05, 2014 10:49 am
Thanks HighlyJetted just what i needed.
BigRon
BigRon
Re: door dropped
Post by Guest on Sat Dec 06, 2014 8:23 am
For a temporary measure I just get my Mobile Bear Traps under  the bottom edge ( below door handle)  and Gorilla the door upwards so the lock and catch line up and it shuts like new.
Not the proper way  I know but have used the same trick on all cars for the past 35 years.
Doesn't work on early Mini's though with exterior hinges.!!
I have  plenty of hinges if you so desire.
07863030309.
Re: door dropped
Post by BigRon on Sun Dec 07, 2014 8:07 am
Hi Woody,
I swapped the top hinges over, near side off side, there is still a bit of slop caused by the bottom hinge on off side so I will probably need one at some time. How much are they.
BigRon.
BigRon
Re: door dropped
