Engine model
Engine model
Post by Penny PP on Fri Dec 05, 2014 7:06 pm
Hoping someone can help me with a seemingly dumb question :-0 I'm trying to local a part for my Piaggio Porter that is on a '57 plate with a 1300 engine. Thought I would try those online breakers but the first one asks make etc then when it comes to engine size the drop down box has 9 different options for a 1.3 :-0 Holy Cow !!!!! How am I to find out which one I have...I just get in it and drive :-0 it's 1300 & uses unleaded fuel. I know its not the 4x4 option. The log book just says 1300cc engine.
Anyone know where I would find out ?..
Penny PP
Re: Engine model
Post by FrontBackSide2Side on Fri Dec 05, 2014 8:07 pm
what are the options? I take it some options would be van, mpv, pickup, chassis cab?
Re: Engine model
Post by Penny PP on Fri Dec 05, 2014 9:27 pm
Trying to post a scrren shot shiwing all the options without much luck :-0
Penny PP
Re: Engine model
Post by HighlyJetted on Fri Dec 05, 2014 9:49 pm
It has a HC-E
Same in all of them from 1996 ish though to 2012 ish?
The only differences are the ignition system/coil packs, and the inlet manifold has an EGR on the post 2001 models.
You can use any age engine in any van, you just have to swap a few little bits about.
Re: Engine model
Post by Guest on Sat Dec 06, 2014 7:34 am
The point is Penny - you leave us all in the dark - - what part(s) are you looking for??
Matt or I may be able to help you with what you what you need. Ask away. Rolling Eyes Rolling Eyes
Re: Engine model
Post by HighlyJetted on Sat Dec 06, 2014 7:58 am
Penny PP wrote:Trying to post a scrren shot shiwing all the options without much luck :-0
Or just post a link to the page you are struggling with.
Re: Engine model
Post by Guest on Sat Dec 06, 2014 8:11 am
When  Penny called  me  last night she used her Christian name  which kind of threw me but this morning have put  two and two  together and actually come up with four  so excuse my post about  which part you needed this morning.  Plus when you  called at 7pm I was still working on a job for a customer replacing a totally rotten floor in a Chalet. Have also had two days  roofing  work prior to that and was in agony with my Arthritis and this morning I feel  like an old man.  Shut up Waz.  I don't need your reminders!!  Razz Razz
Re: Engine model
Post by Penny PP on Sat Dec 06, 2014 8:49 am
http://www.micksgarage.com/quick-search/cars.aspx?vrm=SF57%20GBU Thanks HJ this is the link to the page. I put in the reg but it didn't want to know...said it only recognises uk plates :-0 funny that !!! So using the drop down boxes it gives 9 options for 1300 engine sizes :-0
Penny PP
Re: Engine model
Post by bushwhacker on Sat Dec 06, 2014 12:09 pm
Doesn't seem to be a very good site.
It did take my registration number but then asked whether it was a bus or a van. Grr, it is supposed to know!
Trying it for 1300 with no reg it gave 7 bodywork options and several engine options only one of which was 1.3 so on that basis it looks straightforward. Just choose body type with the correct registration / production date range.
Re: Engine model
Post by HighlyJetted on Sat Dec 06, 2014 4:20 pm
Either pick:-
1.3i 167v 1295cc if yours in the HC-E engine (check CC's on your v5c document)
or
1.3 (72hp 1308cc) if it is the non Daihatsu engined model - check cc's on v5c
Re: Engine model
Post by PFM on Sat Dec 06, 2014 5:20 pm
I didn't know about the 1308cc engine - who made it? Wonder which one I have - my V5C says 1300cc but engine No. starts HC, so I guess it's the 1295
Re: Engine model
Post by Guest on Sat Dec 06, 2014 7:33 pm
Is that the Toyota VVTI lump as in the Extol and Atrai Matt??
Re: Engine model
Post by Penny PP on Sun Dec 07, 2014 8:36 am
My v5 says 1300 too. That was the first place I looked before posting on here. I shall try trawling the net more today to try to locate this part. Gotta be one out there somewhere
Penny PP
Re: Engine model
Post by HighlyJetted on Sun Dec 07, 2014 10:22 am
Please take a photo of what the engine looks like from under the passenger seat.
I'll tell you what you've got!
What part are you actually after?
Re: Engine model
Post by Guest on Sun Dec 07, 2014 10:29 am
Nearside front hub assembly Matt. I haven't got one on the shelf and can't strip one off a van without causing myself logistical problems moving vans in the yard.
Re: Engine model
