New member 1.3 vs 1.0
Post by richardsoniscool on Mon Oct 11, 2010 10:04 pm
Pants! iv put his in the wrong section! could admin please move thx.
Hi, im a new member im yet to get myself a Hijet but im on the search. Me and my Girlfriend would ike it for weekends camping ( we don't need alot of room) and as a general runabout, so im looking at the MPV version as it seems to be the most versatile. There are a couple on ebay at the minute, one is a 1.3 with 80k on the clock but is a bit scruffy, the other is a 1.0 with only 34k but has an overheating problem. im unsure of which to go for as im a competent home mechanic so the overeating doesn't worry me but the 1.0 engine might be a little too sluggish for me. Has anyone compared the two?
here are the links for the ones on ebay. cheers. Mike
1.3 - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250706844165&ssPageName=STRK:MEWAX:IT#ht_500wt_949
1.0 - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320598911355&ssPageName=STRK:MEWAX:IT#ht_500wt_949http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320598911355&ssPageName=STRK:MEWAX:IT#ht_500wt_949
richardsoniscool
Re: New member 1.3 vs 1.0
Post by rich the mechanic on Tue Oct 12, 2010 9:42 pm
Hi welcome, we were looking at the 1.3 but it was too far for us it would have been a up grade to as we have the 1.0 at the mo and the other one was to far away with a problem that may or may not be straight forward as the question is why has it got a air lock if it were round the corner it would have been a different matter.
Post by difflock123 on Wed Oct 13, 2010 7:15 pm
At the end of the day, the hijet isnt a very powerful vehicle in either engine...
the 1.3 I think produces around 60hp
the 1.0L is around 48hp.
But they have the advantage, that they are fairly light...
I have a 1.0L and its great Smile
It will do ~80mph on the flat if you push it.
But a month or 2 ago, I had 12 bags of sand (25kg each) and 4 bags of cement (also 25kg each), so 400kg in it.
And it still pulled to 60mph with ease, and even on a long hill out of a 30mph village, it accelerated to 55mph easily...
I havent been in a 1.3 but I reckon it would be nippier, but the 1.0L has a 3 cylinder engine, so its surprisingly grunty Smile
Economy, I heard the 1.3 is a little better, but I get 30~35mpg from my 1.0L, and I thrash it to be perfectly honest Razz
Either way though, enjoy it Smile
i got it :P
Post by richardsoniscool on Wed Oct 13, 2010 8:24 pm
hey, thanks for the replies, i bid on the 1.3 silver one and got outbid by 20 quid >( but i won the 1.0 blue one which im happy about. its done really low miles and i hope the overheating wont be too hard to fix ill justtake some tool a new rad cap and lots of coolant with me.
and it only gonna cost me £35 to get from Suffolk to Bristol on the train Razz
expect a build, project, modding type thread up here very soon.
Mike
richardsoniscool
Over-heating
Post by emmabskin on Thu Oct 14, 2010 10:05 am
Beware of underestimating the dreaded over-heating in Hi-jets. affraid Twisted Evil
It might be worth checking out how to bleed the system before you go.http://wp.me/pVul6-1D
Cheers Emma
emmabskin
Phone number
Post by emmabskin on Thu Oct 14, 2010 10:13 am
Tony says if you get stuck near Bath you can always call us we've got plenty of spares.
07599056555
emmabskin
Post by difflock123 on Thu Oct 14, 2010 7:13 pm
Mine overheated when I got it (well it started too Razz)
I kept topping the coolant up, but got fed up.
So I got a pot of K Seal, and poured it into the radiator.
That was a while ago now Smile
No problems since...
I highly recommend K Seal to anyone. Its the only fix that actually seems to work, and not make matters worse...
Post by richardsoniscool on Fri Oct 15, 2010 2:18 pm
Thanks for the number I will keep it to hand, I plan to run the engine up and remove the heater bleed cap to let air escape ill take a new rad cap also and hopfully it will be ok. Anything else I should check ? Or take with me? thanks alot. Mike
richardsoniscool
