sensing valve
sensing valve
Post by GEORDIE on Mon Jan 19, 2015 7:56 pm
HI ALL
is there supposed to be a dished washer
on the free end on the spring (lever end)
it looks like the mounting bracket has bent
and the opperating rod is flapping free
thanks Geordie
GEORDIE
Re: sensing valve
Post by Guest on Tue Jan 20, 2015 3:11 pm
There's supposed to  be a white Nylon split, shaped washer. I have in 11, no 12 years of dismantling now,  had a good one.
They are  always worn to excess unless someone has put their hand in their pockets and bought a new one like you probably will have to do.
Re: sensing valve
Post by GEORDIE on Tue Jan 20, 2015 3:25 pm
Thanks Woody
I thought there must have had something in there,I am sure that I will find something that will do the job,the beast failed the M.O.T. on rear brakes and as HJ pointed out on a older post,the bracket was bent,and the bracket that is welded to the rear axle wasnt! that will be welded back on Thursday then hopefully a new ticket!!
GEORDIE
Re: sensing valve
Post by GEORDIE on Fri Jan 23, 2015 7:31 pm
Very Happy Welded the wayward bracket onto the rear axle
ajusted the lspv and now got the tickect for another year,lesson should have looked underneath
first!!
GEORDIE
Re: sensing valve
