Pickup Engine Cover Wanted
Post by Red Dog on Wed Feb 11, 2015 6:14 pm
Just bought a 2001 Hijet pickup with a demountable Romahome on top. On removing the camper I discovered a large hole where the engine cover should be. Does anyone know where I can get a replacement engine cover at a reasonable price?
Red Dog
Re: Pickup Engine Cover Wanted
Post by Logi on Wed Feb 11, 2015 7:18 pm
HJ or Woody are bound to have one?
Post by HighlyJetted on Wed Feb 11, 2015 10:05 pm
I scrapped one about 2 months ago. That was the only one I had Sad
Post by d1noh on Sun Feb 15, 2015 7:21 pm
I have one that I would sell for £25 if required
Post by Guest on Mon Feb 16, 2015 10:14 pm
It is left off at the Factory for a reason. Access to the gearbox from the internal removable floor inspection panel directly above the gearbox inspection hole. If you don't have a panel above the hole then the bodyshell you have isn't Daihatsu - its a Honda and you MUST leave the metal cover off or the body will not fit properly as it is raised above the pickup bed level.
If your inside Cover is at the galley end of the body floor it is definitely off a Honda.
Post by Red Dog on Tue Feb 17, 2015 6:30 pm
Thanks for that info.  The reason I'm after a cover is I've taken the camper off for a while and I need something to stop everything falling through the bed of the pickup.
Red Dog
Post by Guest on Tue Feb 17, 2015 7:00 pm
Then I suggest you take D1noh's offer up then pretty quick and thank you for the Thank you.
If you need Romahome bits give me an email to hi.jetmaniow@gmail.com
My mobile is off for a few weeks while I carry out work on my Workshop until the end of March.
Post by Red Dog on Wed Feb 18, 2015 5:54 pm
Thanks everyone.  I've now got one, courtesy of Dino.
Red Dog
