Clutch slip
Clutch slip
Post by leopard_pagan on Thu Feb 12, 2015 10:18 am
Last few days I've felt loss of pull, today hooning it down a slip rd in 4th it was all Rev & no go, same for 5th.
Where does one get the parts 1.3 petrol? Easy job or not? Engine in or out?
Re: Clutch slip
Post by HighlyJetted on Thu Feb 12, 2015 6:57 pm
Gearbox out job.
I'll have a look at home tomorrow for a decent 2nd hand clutch.
Re: Clutch slip
Post by leopard_pagan on Thu Feb 12, 2015 7:29 pm
I texted you HJ, did you get it?
Cheers.
Re: Clutch slip
Post by leopard_pagan on Sat Feb 14, 2015 10:24 pm
Will I also need a bell housing gasket when I replace the clutch?
HJ did you get my text I sent mate?
Re: Clutch slip
Post by Guest on Mon Feb 16, 2015 9:54 pm
There is no gasket LP. Just the. Metal Shite Shield.
Re: Clutch slip
Post by leopard_pagan on Mon Apr 13, 2015 10:32 am
Got it done yesterday after a blood sacrifice was made (mate helping spilt his head open while emerging from under the van on the open sliding door!) The only pain in the arse was getting all the various cables/electrics disconnected/out the way before dropping the gearbox.
Even then we didn't spot the reverse sensor & wires got pulled out! Just as well I do electronics & re soldered/crimped it back together.
The earth bolt was the only one that sheared off! Repositioned it on to the speedo cable bolt.
Clutch was dry (no oil leaks) & worn almost flat!
Now to get used to a new clutch...
Re: Clutch slip
