998 efi not starting after head gasket + vid
Post by leopard_pagan on Sun Oct 24, 2010 6:42 pm
Hi all, we've got the head back on from skimming, new gasket, gasket sealant, made sure the cams were alined and it turned over by hand with out valves hitting anything!
All parts back on/connected and the van wont start! It turns over on the starter but no final kick.
All 3 spark plugs keep on fouling with fuel/oil mixture. Ht leads on correctly as I wrote on each one what cylinder it came from.
Any ideas?
Re: 998 efi not starting after head gasket + vid
Post by rich the mechanic on Sun Oct 24, 2010 6:50 pm
check the exhaust is it getting warm after a long spin over if so then the timing is out by one tooth, the cam is retarded and induction is late, spark is late therefore burn is late and in the exhaust while still burning.
