So what's wrong with my rear door?
Post by Gra on Thu Mar 12, 2015 6:00 pm
Rear door shuts fine, just a bit of a slam. But after drivng a short distance I hear a click and the damn thing rattles from them on. Anyone know what the fix is for this?
Gra
Gra
Re: So what's wrong with my rear door?
Post by Swarfing on Wed Apr 01, 2015 11:14 pm
The catch plate needs adjusting. Loosen the bolts and push it further into the van.
Swarfing
Post by Guest on Thu Apr 02, 2015 2:02 pm
It's usually the spring loaded catch that grips the latch plate that gets rusty and seizes up. It is spring loaded.
Undo the two 10mm set bolts and take the catch off and disconnect the thin operating rod and take the catch assembly off and give it a dose of WD40 and work the catch and the latch arm which is also spring loaded and work it back and forth and loosen both up.
If the two position catch isn't springing back into the open position assuming that the WD40 has loosened it up then the spring is broken and the whole catch assembly will need to be replaced.
Post by HighlyJetted on Thu Apr 02, 2015 8:40 pm
Yeah, take it off, and work it loads with wd40, wash the bugger out with it.
Keep opening and closing the lock with loads of wd40.
Life will be better!
I lost 2 tool boxes once going over a speed hump to a dodgy hijet boot catch. All my stuff all over the road.
Post by Guest on Thu Apr 02, 2015 9:59 pm
Ouch!!! That was an expensive lack of WD40.
I have done exactly the same though, but luckily my tool box was locked and just suffered a few scratches and dents.
Post by leopard_pagan on Sun Apr 12, 2015 8:19 pm
My door just rattles! might have to take a look. all works fine though
Post by Guest on Sun Apr 12, 2015 8:21 pm
Must be Logi in the back rattling the back door.
Post by leopard_pagan on Sun Apr 12, 2015 8:25 pm
lol!
Oi, while ya back there..... fix the rattle luv
Post by Guest on Sun Apr 12, 2015 8:32 pm
Nice one L.P. Laughing
Post by Gra on Fri May 01, 2015 9:00 pm
Thanks Woody/HJ, the WD did the trick. Everything works fine now.
Gra
Gra
Post by Logi on Sat May 02, 2015 10:35 pm
If I'm rattling your back doors you'll not need WD40...... Wink
Post by Guest on Sat May 02, 2015 10:48 pm
Whiskey???
Post by PFM on Sun May 03, 2015 12:03 am
Vaseline???
Post by HighlyJetted on Sun May 03, 2015 9:32 am
Morphine ?
Post by Guest on Sun May 03, 2015 9:38 am
Any advance on Morphine anyone ???
Post by Swarfing on Sun May 03, 2015 11:47 am
If I'm rattling your back doors you'll not need WD40..... wrote:
Must be very lose then or small part if not needed Laughing
Swarfing
Post by Logi on Sun May 03, 2015 2:29 pm
It may be a small part but it's perfectly formed  Shocked
Post by Swarfing on Sun May 03, 2015 4:31 pm
As long as it works and not too many fluid eruptions it should last you a good time.........It was a heater issue wasn’t it? Embarassed
Swarfing
Post by andy pyke on Wed May 06, 2015 10:57 am
Rohipnol
andy pyke
