soggy footwells
soggy footwells
Post by sputnik on Fri Mar 13, 2015 10:50 pm
Sure I saw a thread about this ages ago when I didn't need it and now can't find it when I do... Rolling Eyes
As the title suggests, front footwell carpets are damp/ wet underneath, both sides but driver side is worse. I had put this down to my leaky sunroof but now think it is unconnected. I'm not 100% sure if the water ingress only happens whilst on the move or also when parked up.
Basically, is this common, and if so can anyone give any pointers for where I should be looking for a likely source of the leak to save me hours of fannying around? 2000 1.3 MPV if that makes a difference.
sputnik
Re: soggy footwells
Post by elfin girl on Fri Mar 13, 2015 10:59 pm
my drivers side is soggy too Shocked
not had a chance to find out where its getting in tho, the windscreen looks ok from the outside, i think it might have been getting in lower down from road spray when its raining.
sorry not much help, if i figure out where its getting in ill post again!
Re: soggy footwells
Post by HighlyJetted on Sat Mar 14, 2015 10:46 am
Rear headlight covers?
Seals round the bottom of the doors?
Heater matrix?
Brake master cylinder?!
Re: soggy footwells
Post by Logi on Sat Mar 14, 2015 11:16 am
Steering column?
Re: soggy footwells
Post by HighlyJetted on Sun Mar 15, 2015 2:34 am
did you piss yourself?
Re: soggy footwells
Post by sputnik on Sun Mar 15, 2015 8:40 am
HighlyJetted wrote:did you piss yourself?
Ah, now you mention it.... Embarassed
sputnik
Re: soggy footwells
