Fitting Kit (Clips/Pins for front brake pads)
Post by g149 on Sun Mar 15, 2015 5:55 pm
Can't seem to find a fitting kit (pins & clips) for hijet (2005) brake pads. Can anyone assist? (Or even just used retaining clips from one side). Thanks.
g149
Re: Fitting Kit (Clips/Pins for front brake pads)
Post by Scarface GTti on Mon Mar 16, 2015 10:42 am
Had a look on Brakes International but they don't list Hijet, dealer should be able to supply.
Scarface GTti
Post by HighlyJetted on Mon Mar 16, 2015 6:42 pm
Second hand is the easiest way.
Post by Guest on Sat Mar 21, 2015 7:07 am
I keep new brake pin "R"   clips in stock. Got hundreds of them literally. Can't seem to source the pins though. .
 I also keep loads of sliding door ball race rollers but not the nylon wheels and the 60amp yellow PAL main fuses { under drivers seat}.
07863030309 hi.jetmaniow@gmail.com
