would a Daihatsu porter headlight fit a Hijet efi 2003 ?
Page 2 of 2 Previous  1, 2
Re: would a Daihatsu porter headlight fit a Hijet efi 2003 ?
Post by Swarfing on Sun May 17, 2015 9:48 am
Well I pressed BIN on some last night and will give it a try when it comes and will post pics and findings.
Swarfing
Post by Guest on Sun May 17, 2015 9:53 am
Brave Man !!
Post by HighlyJetted on Sun May 17, 2015 11:01 am
woody wrote:One concern would be how much heat it can sustain. A normal Halogen 60/55w bulb gives off a hell of a lot of heat and the top of the reflector gets exceedingly hot.
The bulbs I use in my Hi-Jet's are 100/80w and 130/100w in my  MPV so double the light and heat so would be interested how the wrap could cope with the higher power bulbs. You can't buy the 130/100w bulbs any more but I still buy the 100/80w ones and have loads of them in stock but sadly I have only got 4 of the 130/100w left now.
Watch out you don't cook your wiring loom pulling all that current though the little Hijet headlight wiring.
These high power bulbs will be even hotter then the original wattage lamps.
Post by Swarfing on Sun May 17, 2015 11:24 am
Brave Man !! wrote:
Only cost £4.00 for enough to do two lights? If it don't work it will peel off Very Happy
Swarfing
Post by Guest on Sun May 17, 2015 11:36 am
Got them on two relays Matt so the dipswitch is handling very little current. . I had the same wattage bulbs in a couple of my cars plus four 150 watt Spotlights on relays so all toled 1060watts when on dip beam with headlight flash pulled up.
Nobody flashed me twice I must say.
Post by Logi on Sun May 17, 2015 6:57 pm
Nobody's flashed me in ages...........  Razz
Post by Guest on Sun May 17, 2015 7:00 pm
Something to do with your age obviously.
Post by peekatu on Sun Jun 14, 2015 1:08 pm
Well  I  got the paint But can't get the glass off      Sad  MOt  soon       what if I  put new brighter bulbs in  the headlight Do u think it would pass then  ? I don't know if they check the brightness of the  light  or the condition of  the headlight ? Question
peekatu
Post by peekatu on Wed Jul 01, 2015 3:07 pm
Van headlight Respraying With chrome ..update
peekatu
Post by peekatu on Wed Jul 01, 2015 3:08 pm
glass off and   cleaned
peekatu
Post by peekatu on Wed Jul 01, 2015 3:09 pm
peekatu
Post by peekatu on Wed Jul 01, 2015 3:11 pm
First coat of PRIMER
peekatu
Post by peekatu on Wed Jul 01, 2015 3:12 pm
[/im   Second coat of paint Black" />
peekatu
Post by peekatu on Wed Jul 01, 2015 3:14 pm
First coat of Chrome            ... Hope it works Very Happy
peekatu
Post by peekatu on Wed Jul 01, 2015 4:49 pm
Does anyone have glass for a drivers side headlight for daihatsu hijet EFI  2003    ?         Please  Embarassed
peekatu
Post by Logi on Wed Jul 01, 2015 4:58 pm
Gonna need to try this myself Sad
Post by Guest on Wed Jul 01, 2015 5:24 pm
That's not a very bright idea Logi.
Post by Logi on Wed Jul 01, 2015 5:35 pm
woody wrote:That's not a very  bright idea Logi.
Yeah, but neither's my headlamps....
Post by Raggy on Wed Jul 01, 2015 10:00 pm
Dont know if anyone has thought about this but I'm involved in cycling and some carbon bike have had a chrome finish applied to them, hard to tell diference without flicking tube if its chromed steel or chrome effect on carbon. Maybe this finish could be used for the headlight refinish. Seen companies advertising they can put various finishes on plastic, wood effect, camoflage etc sure I have seen one who did chrome. Option instead of spraying.
Post by PFM on Wed Jul 01, 2015 11:00 pm
Sadly, bicycles don't need to pass the MOT test
