ministry of transport test
Post by rich the mechanic on Wed Nov 10, 2010 4:51 pm
Wahoo the van has a new MOT now but did fail the first emmissions test turns out the sensor under the hand brake is supposed to have a vacuum pipe from the manifold attached it never was on ours and that was because the spout off the MAP sensor had snapped off and someone previous had mastic'd it back on at sometime now with a replacement it runs better and the MPG should be loads better as it was doing about 15 to the gallon so beware if you have shit fuel economy it maybe the sensor tucked away next to you.
Re: ministry of transport test
Post by leopard_pagan on Wed Nov 10, 2010 6:37 pm
aye, saw all the silly pipes when we took the handbrake plate up. did make sure we put em all back on when finished.
