Fast Idle Speed
Fast Idle Speed
Post by Red Dog on Thu May 14, 2015 5:35 pm
My 2001 Hijet has a really fast tick-over, especially when cold. Is there any adjustment?
Red Dog
Re: Fast Idle Speed
Post by Swarfing on Thu May 14, 2015 7:45 pm
It should do that normally and reduce as it gets warmer.
Swarfing
Re: Fast Idle Speed
Post by Red Dog on Fri May 15, 2015 1:02 pm
I thought that was the case but this just seems a bit too high for comfort.
Red Dog
Re: Fast Idle Speed
Post by Swarfing on Fri May 15, 2015 7:38 pm
It should be 850 +- 50 RPM at first switch on (Acording to the label on my passenger door).
Swarfing
Re: Fast Idle Speed
Post by Red Dog on Fri May 15, 2015 10:50 pm
Mine is much higher than that.
Red Dog
Re: Fast Idle Speed
Post by Swarfing on Fri May 15, 2015 11:24 pm
Should have said after warm up
Swarfing
Re: Fast Idle Speed
Post by Red Dog on Sat May 16, 2015 9:30 am
Still too fast, even when hot.
Red Dog
Re: Fast Idle Speed
Post by Swarfing on Sat May 16, 2015 6:08 pm
What's it like once warm, is there any adjustment on the throttle cable?
Swarfing
Re: Fast Idle Speed
Post by Logi on Sat May 16, 2015 7:47 pm
There's a wee pipe that if blocked doesn't let warm coolant through to switch off the over fuelling hence higher revs.
Re: Fast Idle Speed
Post by Swarfing on Sat May 16, 2015 8:31 pm
If the wee pipe is blocked then it could be gall stones?
Swarfing
Re: Fast Idle Speed
Post by Red Dog on Sun May 17, 2015 7:11 pm
It's not the throttle cable. That was the first thing I checked. It does slow down to some extent as it warms up. It seems to do everything it should but at twice the engine speed.
Red Dog
Re: Fast Idle Speed
Post by chinfuk on Sun Jan 24, 2016 12:47 pm
Where is the wee pipe, mine is doing that too after a head gasket replacement, did you get yours fixed red dog
chinfuk
Re: Fast Idle Speed
