Are these an easy fix
Post by Raggy on Wed Jun 24, 2015 10:07 pm
Thought I had posted this before but cant find it, so appologies if it appears twice! After looking through a few adverts etc seems there are a couple common problems, fuel guage not working and door handle from outside broken. Are these 'easy' fixes? I know the answer could be 'how long is a piece of string' but wondered if they are issues that cost alot to fix, worthwhile knowledge when haggling a price.
Re: Are these an easy fix
Post by HighlyJetted on Wed Jun 24, 2015 10:40 pm
Proper good condition sliding door handles are getting hard to find.
A guy sells poor fitting poor quality copies on ebay for about £20 each.
They work - for a bit.
Fuel gauge - half the time its the ground wire, the other half its the fuel float itself.
You have to take the fuel tank out, and a brand new sender can be ordered from italian ebay for about £45.
Post by Raggy on Wed Jun 24, 2015 10:43 pm
Thanks, sounds feasable then.
Post by andy pyke on Thu Jun 25, 2015 9:46 am
Those sliding door handles he sells don't quite fit do they? You need to file a bit of the plastic off to make them fit snug. They're also quite fragile so unless you have a sweetly gliding door and have instructed the kids/wife/whoever to be gentle, they're going to break again.
I need to do both of mine but last time I tried it was a nightmare. Never quite got the mechanism to work properly.
andy pyke
Post by Eightpot on Thu Jun 25, 2015 5:59 pm
My sliding door handles are fubared. My easy fix is to reach inside and open via the internal door release. I don't see it as an inconvenience, merely an added security feature. clown
Eightpot
Post by bushwhacker on Thu Jun 25, 2015 6:29 pm
Trouble is, non working sliding door handles are an MOT failure (for the MPV at least). So when mine failed I gave them two door handles and said "ok, you fit them then". Did a good job too.
Post by HighlyJetted on Thu Jun 25, 2015 10:28 pm
Yes, if there are rear seats the handles must be present.
Post by Logi on Fri Jun 26, 2015 6:11 am
Mine are buggered as wrll, I just remove the 3rd sest in the back come MOT time. Bloody annoying tho
Post by PFM on Fri Jun 26, 2015 11:25 am
andy pyke wrote:You need to file a bit of the plastic off to make them fit snug.
I fit a washer between the handle and the door. They still don't last long, though.
Post by HighlyJetted on Fri Jun 26, 2015 8:31 pm
If you pack them off with washers they will break quicker due to the force applied to the tapped bosses.
Post by PFM on Fri Jun 26, 2015 9:15 pm
Even if it's all well lubed?
