How to set ignition timing?
Post by CoolJet on Sat Jul 25, 2015 9:33 pm
I messed up ignition timing during HG change. I need to set it up again. So if i turn the pulleys to the drill mark alignment like when i set up the timing belt would that be the dead center for cylinder 1? Anyone here who can tell me how i set the ignition correctly without special tools? confused
CHEERS!
CoolJet
Re: How to set ignition timing?
Post by CoolJet on Sun Jul 26, 2015 4:11 pm
solved.
CoolJet
Post by HighlyJetted on Mon Jul 27, 2015 8:31 am
Set it with a timing light too.
I have not had a single 993cc turn up with the timing set right.
Double check all your vacuum lines too. Make sure there is vacuum to the MAP sensor.
