Noise in rear axle when decelerating
Post by sunnylife on Sun Jul 26, 2015 8:34 pm
Hello Gentlemen!
I am female owner of Piaggio Porter 2009, so please bear with me.  Embarassed
I drive Porter because I am going to move the Romahome demountable box to this chassis from my old Suzuki Supercarry.
Before that, I am trying to fix some noise that I get in the rear axle, when decelerating. I understand from various sources that this noise is because of too much backlash in the rear differential and needs adding/moving some shims to adjust that backlash.
Do you know of any garage who would be ready to do such adjustment in Piaggio Porter? (I can drive anywhere in the UK – this is why I have a camper!)
Or may be some of you, self-masters,  could do such job for me?
Many thanks
Elena
sunnylife
Re: Noise in rear axle when decelerating
Post by HighlyJetted on Mon Jul 27, 2015 8:27 am
Before you go too far into major works.
Make sure the UJ's on the prop shaft are working freely by unbolting one end of the prop shaft.
And make sure the oil is changed in the diff.
These two simple little jobs may shut up the drone.
Welcome to the forum cat
Post by sunnylife on Mon Jul 27, 2015 4:34 pm
Thank you very much – this is a good idea.
I actually just topped-up the axle differential oil, for these very reasons.
Now I wonder, if I should change the dif. oil using the one with higher viscosity – could it partly compensate for too much backlash and at least reduce the noise ?
sunnylife
Post by Logi on Mon Jul 27, 2015 5:01 pm
Check the shaft first, it's a known issue, mine was noisy, sounded like the diff.
Post by HighlyJetted on Mon Jul 27, 2015 5:51 pm
Any old shaft master can do it
Post by F3rob on Sun Nov 22, 2015 10:45 pm
Hi, could any of you tell me what type of oil is used for the rear diff please?
F3rob
Post by F3rob on Sun Nov 22, 2015 10:46 pm
F3rob
