Check Engine Light Code Reader
Post by Gampy on Wed Jul 29, 2015 9:51 pm
Hi to everyone. I am new to the forum and glad to be here. I live in Canton, Mississippi, USA on a family farm.
I have 3 Daihatsu Hijet Mini Trucks here in the US. I have a couple of code readers that I can use on American vehicles as well as vehicle brands that are common here like Toyota and Nissan etc. When I try to use these same code readers on my farm mini trucks they don't work. All three of my Mini Trucks are year 2000 Daihatsu Hijet model S210P efi.,  all have the 660cc engine and are all 4x4 and all are right hand drive.
One has a check engine light on. They all have the regular looking OBDll plug by the drivers left knee. Do they take some special reader that I don't have?
Gampy
Re: Check Engine Light Code Reader
Post by HighlyJetted on Wed Jul 29, 2015 11:00 pm
Post by HighlyJetted on Wed Jul 29, 2015 11:01 pm
List of error codes and definitions:-
13 – Rev signal – Crank position sensor fault
14 – Camshaft position sensor Fault
16 – Ignition signal – Igniter unit or wiring
17 – Random/multiple Misfire Detected
18 – Knock sensor fault
21 – Primary Oxygen sensor signal – open or shorted (lambda sensor in exhaust)
22 – Secondary Oxygen sensor - open or shorted
23 – Primary Oxygen sensor heater fault
24 – Secondary Oxygen sensor heater fault
25 – Running too lean
26 – Running too rich
27 – Catalytic convertor efficiency below threshold
31 – Pressure sensor – open or shorted MAP sensor circuit
32 – Atmospheric pressure sensor (BARO) malfunction
36 - Random/multiple Misfire Detected
41 – Throttle position sensor signal – open or shorted (on throttle body assembly)
42 – Coolant temperature sensor – open or shorted
43 – Intake air temperature sensor signal – open or shorted
51 – Switch Signal – Caused by throttle position sensor
52 – Vehicle speed sensor signal – open or shorted
54 – Starter Signal – open or shorted or due to bump start
61 – Engine Control Module – Power Supply
71 – Idle Speed Control System – Fault
73 – Camshaft Position Actuator – Circuit Fault
74 – Oil control Valve – Circuit Fault
75 - Camshaft Position Actuator – Circuit Fault
76 – Evaporative Emission canister purge valve – Circuit Fault
