Won't start
Won't start
Post by ProjectJohnie on Sat Aug 22, 2015 10:12 am
Hi all. I am a recent newbie to Hijet ownership (although have run my faithful sport raj for the last 9 years). When I purchased the hijet it had an issue with cutting out when in town and not starting again for around 40 minutes. I swapped the temp sensor at the back of the block and this necessitated removing the dizzy. I did this and replaced in exactly the same place as it was. The problem now is she won't start. Turns over ignition and engine lights function, have checked the fuse under drivers seat and don't know what else is left to do. Would really appreciate some guidance before giving up and taking to a garage. Thanks in advance JP
ProjectJohnie
Re: Won't start
Post by rich the mechanic on Wed Aug 26, 2015 9:01 am
Hi did you time the engine or just pull the dizzy off? If you just pulled it off bring the engine to its timing marks and pull the dizzy off and line up the marks and try to refit in the marked position, its at 90° and rotates slightly on fitting/removal and easy to get a tooth out.
Re: Won't start
Post by ProjectJohnie on Tue Mar 29, 2016 5:01 pm
HI Rich, So I finally got around to taking a proper look at the Starting issue, and it was down to the dizzy and Timing. Thanks for the info. Surprised
ProjectJohnie
Re: Won't start
Post by Woodie on Tue Mar 29, 2016 5:16 pm
Eh Voilà, & seven months later she works. Would have been soon up for its first Birthday
Re: Won't start
