How can we protect the Hijet from overheating?
Post by Lex_Michdebus on Sat Aug 29, 2015 3:01 pm
I bought a 1995 Hijet recently with only 23.000 km on the dial. The more I read about these vans, the more it becomes clear that there's a very high chance I'll get in trouble in the future with the vans cooling system. Almost every van I see coming by on the local second hand website has a story of replaced gasket or something other overheating related trouble.
Today I saw a pic of a Hijet with the front panel that was replaced with something more open (pictures down below). Will that help? Are there other tricks to be more safe? Replacing the radiator for something bigger perhaps?
Edit: Picture, another picture.
Lex_Michdebus
https://youtu.be/zAH2jjzAhU8
Re: How can we protect the Hijet from overheating?
Post by HighlyJetted on Sat Aug 29, 2015 11:20 pm
The best way to stop them from over heating is by either not driving them, or scrapping them Wink
Post by Logi on Sun Aug 30, 2015 6:28 pm
HighlyJetted wrote:The best way to stop them from over heating is by either not driving them, or scrapping them Wink
Laughing
Post by Swarfing on Sun Aug 30, 2015 9:42 pm
Jokes aside you could always fit a water pressure gauge. This will give you early signs that your water needs attention. It also helps to do as dad always did on a Sunday morning? Check the bloody levels.....You can leave out resetting points and adjusting the carb needle Laughing
Swarfing
Post by Logi on Mon Aug 31, 2015 9:21 am
My thermostat has an extra hole drilled in it, van takes longer to heat up but won't airlock.
Post by HighlyJetted on Mon Aug 31, 2015 12:05 pm
They are much less likely to have a stuck thermostat overheat by keeping the interior heater on hot because it keeps the water feed to the underside of the thermostat open, thus ensuring the thermostat is never kept in stagnant cool water. If you want to kill the heat to the cab, move the vents select knob over to the left.
I will never move my interior heaters over to the blue section. It is a bad idea, and until the coolant system comes upto full operating temperature, it risks the thermostat staying closed. It is a design flaw in how the system is plumbed as there is no cold select bypass plumbed in.
Post by andy pyke on Tue Sep 08, 2015 10:29 am
Ain't that the truth!! Exclamation
andy pyke
