Hijet Parts
Hijet Parts
Post by difflock123 on Sat Dec 11, 2010 12:41 pm
Hello people.
As I think I mentioned before, my hijet is off the road now for 2 reasons...
1 - My Landy is on the road finally
2 - My hijet has run out of MOT and it wont pass another one...
So I was thinking of using the hijet for parts for some of my projects...
but I need to find some info out first...
its a 96 993cc EFI model if it helps...
so here are some questions:
- What ratio is the rear diff? (e.g. 4.7:1)
- I know the propshaft flange on the diff is a 4 bolt, but is the gearbox end 4 bolt or the splined style?
- What ratio are 4th and 5th gear? (I presume 4th is a typical 1:1?)
- Is the hijet built as a monocoque chassis, or can the body work be completely removed, to leave a working rolling chassis like a Land Rover?
I am thinking of possibly building a trike or a homemade garden tractor, or very possibly a off road buggy using the parts...
if I build a trike, the engine/gearbox, the rear diff, and the propshaft will probably stay as they are to give a nippy and yet economical trike Smile
but if I build a garden tractor, I will get a second gearbox, and fit it inline with the first one (either using the hijet engine and gearbox with a different gearbox after the hijet one, or using a different engine and gearbox which then connects to the hijet box...)
The reason for the second gearbox is to act like a transfer box.
in 4th gear (presuming its a 1:1 on the second box), will give the same performance as standard.
but putting the second box into 1st gear, would give an very low ratio.
Thanks in advance Smile
Re: Hijet Parts
Post by difflock123 on Sat Dec 11, 2010 12:51 pm
Also, one other question.
on the EFI 993cc hijets, the manual says about a catalytic converter.
Is it a true cat, full of precious metals, or just a particle filter style one?
if its a true cat, I think it might be worth taking it to a scrap yard for some cash, thats all...
Re: Hijet Parts
Post by PFM on Sat Dec 11, 2010 4:42 pm
According to www.carbuddy.com.au, final drive ratio is 4.875 for a 1990 S85. Might be diff in aussie land though. I'm sure it's monocoque, but can't help with anything else, sorry.
Re: Hijet Parts
