What and where?
What and where?
Post by Raggy on Tue Sep 29, 2015 12:21 pm
Question 1
Found fuse cover in glove box, but where should it fit
Question 2
Found the metal pin on floor near passenger sliding side door, where did that come from?
Re: What and where?
Post by CoolJet on Tue Sep 29, 2015 3:44 pm
right handside (in europe left handside) below the steering wheel is the fuse compartment. The metal pin might be one of the ones from the front doors. Check if it is missing in the middle between the hinges
CoolJet
Re: What and where?
Post by Raggy on Tue Sep 29, 2015 6:14 pm
Thanks, will get cover put back on, was in glove box for some reason. Hmm, will look at door in a bit and see if it fits anywhere, thanks.
Re: What and where?
Post by PFM on Tue Sep 29, 2015 7:12 pm
HotJet wrote:right handside (in europe left handside)
Did the UK leave Europe or were we thrown out? Very Happy
Yes, 1 - on the fusebox, left of steering column inder dashboard, 2- as Hotjet said but I'd have thought you'd notice it's absence so maybe it is an old one or a not-yet-fitted replacement?
Re: What and where?
Post by Raggy on Tue Sep 29, 2015 7:32 pm
Spot on with fuse cover, now back in place...pin is another thing...cant see anywhere it would fit!
Re: What and where?
Post by Raggy on Sun Oct 04, 2015 9:41 pm
Mystery solved! Turns out it was the hinge pin for the leasure battery quick connector. Glad I didnt just throw it away.
Re: What and where?
Post by PFM on Sun Oct 04, 2015 10:15 pm
Glad you found it's home. Reckon most Hijet owners are hoarders, you never know when something might be useful.
Re: What and where?
