bleeding coolant
bleeding coolant
Post by kellyman on Mon Oct 12, 2015 4:00 am
I have an 02 piagio porter with a LDW 1404 diesel engine . I have heard that the coolant system needs bleeding after putting in anti freeze is this correct and can any one advise thanks
kellyman
Re: bleeding coolant
Post by Guest on Sun Oct 18, 2015 5:05 pm
Hi Kellyman. If you haven't managed to bleed your Lombardini Diesel yet then please email me your mobile number and I will put you in my Contacts list and then you can call me back and I will explain the sequence step by step. I have Call Blocker in place so unless you are in my contacts list your call is automatically terminated. My email address is hi.jetmaniow@gmail.com and number to call me on is 0786 303030 9 when you are in my contacts list. Woody.
