Porter load sensing valve
Post by kellyman on Mon Oct 19, 2015 11:01 pm
Hi i have a PIAGIO PORTER 02 1.4 DIESEL and need a replacement for a load sensing valve or does anyone have experience with fixing them its jammed at the moment thanks
kellyman
Re: Porter load sensing valve
Post by PFM on Tue Oct 20, 2015 8:27 am
Several threads on un-jamming these already - search for 'compensator' or 'load'.
Post by Guest on Tue Oct 20, 2015 9:08 am
If you are trying to push the arm and piston upwards then stand on your head and try it the other way. The piston moves downwards.
Get someone to depress the brake pedal while you push the LSV arm upwards. If the arm moves downwards then you are ok. There is only about 3mm's of downwards movement on the piston so the arm isn't going to move much.
