Vacume Pipe Lay-Out
Vacume Pipe Lay-Out
Post by pugwashed on Thu Dec 30, 2010 6:50 pm
Assistance needed:
My Hi Jet has failed its MOT due to emmision issues. Main reason being that the fuel/air pipe has been tampered with by previous owner/s. For fault to be rectified the machanic requires a diagram/lay-out of pipe assembly. Another possibility is that i could look at someones Hi Jet and see the correct assembly an take a few photos. I live in the Cardiff area and will travel to you.
Thank you.
