Rapidly Flashing Check Engine Light EF-SE(S210)
Post by tms on Thu Nov 05, 2015 7:03 pm
hello all, i cam across a problem where my check engine light is flashing rapidly and i am not in test mode. it happened when i tried to perform initial learning which i suppose wasn't required at all. I downloaded the manual uploaded by HIGHLYJETTED and translated it what ever i could or needed through google translator. It explained the initial learning process as follows
"Computer initialization , re- learning I follow the instructions below .
1 to IG ON. ( Engine does not start)
2.
(1). T terminal short circuit ,
(2 ) . Headlight switch ON,
(3 ) . Heater blower switch ON,
( 4) hold Full throttle
more than the four conditions for more than 10 seconds .
3. release all of the above four conditions , to IG OFF.
4. After older than 3 seconds after IG OFF, it is passed by IG ON least 3 seconds . ( System initialization , learning completion )"
when i performed this procedure MIL started flashing rapidly, vehicle is running fine with no issues but flashing MIL is a headache. If any one has any idea about this issue please help me; i am uploading the translated manual here for any one who may need it.
https://drive.google.com/file/d/0B9zn2-c1CPOHdTAydWZRTmpmUnc/view?usp=sharing
tms
Re: Rapidly Flashing Check Engine Light EF-SE(S210)
Post by tms on Mon Nov 09, 2015 2:25 pm
any one with some insight of this issue ???
tms
Post by Manks on Fri Jul 22, 2016 4:56 pm
Similar to the procedure for a Brazilian T2 (not a new haircut!) but turn off the ignition before releasing throttle.
Manks
Post by HighlyJetted on Fri Jul 22, 2016 7:01 pm
flashing quickly usually means no fault codes on daihatsu's
