Heater Control Panel Lighting
Post by Gra on Thu Nov 12, 2015 11:07 am
The bulb has blown on the lighting panel. I've removed the two screws under the panel and pulled the surround off. I've also removed the two screws either side of the panel but where do you go from there?
Gra
Gra
Re: Heater Control Panel Lighting
Post by PFM on Thu Nov 12, 2015 1:22 pm
If you've removed the 2 screws either side of the levers you need to ease them forward and you will see the bulb behind it IIRC.
Post by Gra on Thu Nov 12, 2015 4:19 pm
PFM wrote:If you've removed the 2 screws either side of the levers you need to ease them forward and you will see the bulb behind it IIRC.
OK thanks. Sorted.
Gra
Post by elfin girl on Thu Nov 12, 2015 6:20 pm
thats supposed to be lit?! better have a look at mine then Smile
Post by Guest on Thu Nov 12, 2015 11:14 pm
It is such a pig awful bulb to get to especially with mobile Beartraps for  hands like mine. The amount of wire on the loom they DON'T GIVE YOU  is ridiculous.
