Daihatsu Hijet 16v Efi. Urgent PLS help
Post by Missmojo on Sun Dec 13, 2015 4:11 pm
Hi all.
My van won't start. It's turning over but not firing. Oh it's a 4 wheeled drive too.
There is no hum when I turn the ignition to on.
I am presuming this is the fuel pump.
So........
1) where is the relay to the fuel pump (APPARANTLY it might be this?)
2) where is the fuel pump. Is it in the petrol tank??
3) could it be anything else??
Thank you so so much in advance.
But I want to sell this van as it has a Romahom on it.
Was up for sale but today when I had someone coming....Sod's law, it won't start!!
Aaarrrggghhh
Missmojo
Re: Daihatsu Hijet 16v Efi. Urgent PLS help
Post by Missmojo on Tue Dec 15, 2015 7:40 am
Anyone please???
Missmojo
Post by Guest on Tue Dec 15, 2015 10:24 am
I sent you a Private Message last night Miss Introuble to contact me. If you email me your mobile number then I will put you in my Contacts list then you will be able to call me. I have Call Blocker in place to stop unknown callers. My email address is : hi.jetmaniow@gmail.com
Post by Missmojo on Tue Dec 15, 2015 4:50 pm
Thank you.
Email sent.
Im out until 7
Missmojo
Post by Guest on Tue Dec 15, 2015 4:55 pm
Got your email. Smile  Will phone you after 7pm. That fits in well with what I am working on now.
Post by ollylewis on Fri Feb 26, 2016 6:41 pm
Good Evening, i am currently having the same issues with my van. Not a 4 wheeled drive.
I have checked the fuel pump and that is fine. But there is no power getting to it. Did you work out what the problem was?
ollylewis
Post by Missmojo on Fri Feb 26, 2016 6:51 pm
Hi there,
Yes it was the Ignitor. They cost bloody loads new (£400+) so look on Ebay for someone scrapping a van as I found one for £100
Good luck!
Missmojo
Post by wrightgeordie on Fri Feb 26, 2016 7:03 pm
Guys
Check the twin fuse block next to the ECU Ive just had the same problem and it was one of these that was at fault.  Check my Fuel Pump Fuse post from the other day
wrightgeordie
Post by ollylewis on Fri Feb 26, 2016 7:19 pm
Yes i seen that this afternoon, i am praying that it is just that. As a got the van for under £400.
ollylewis
Post by Woodie on Fri Feb 26, 2016 11:19 pm
Why didn't you ask me?? I have Igniters in stock. It would have saved you £25.
Post by ollylewis on Fri Feb 26, 2016 11:23 pm
My question is before I look at it tomorrow where is the fuel filter fuse in a 1997 hijet. If it is not near the computer?
ollylewis
Post by Woodie on Fri Feb 26, 2016 11:29 pm
Why or how even would a Fuel Filter have a fuse? I guess you mean Fuel Pump. Bear in mind that the 993cc Van wiring is different to the 1300 models.
Post by ollylewis on Fri Feb 26, 2016 11:43 pm
Sorry, I should have read that back fuel pump fuse. It is a 1997 993cc MPV
ollylewis
