Blowing fuses
Blowing fuses
Post by a team on Sun Jan 17, 2016 7:10 pm
Hello wonder if anyone could help me, I was driving and indicated then the fuse blew stopping the indicators and wipers working so I replaced it ,switched ignition on with no instruments on then it blew again so put another fuse in same thing happened blew, I repeated this 4 or 5 times blowing each new fuse I put in, so it blows a new fuse every time I switch the ignition on when the red lights come on and I don't know much about electrics anyone have any ideas? all help appreciated many thanks, darren
a team
Re: Blowing fuses
Post by andrewmole1 on Tue Feb 23, 2016 8:06 pm
hi could be the rear wiper electrics, the wires get rubbed through on the rear door hinge. Make sure rear wiper is switched off (or unplugged) then try a new fuse.
Good Luck
andrewmole1
Re: Blowing fuses
Post by Raggy on Tue Feb 23, 2016 8:27 pm
Was just going to say something sounds as if its being shorted somewhere. Someone else on here had a similar issue and it was a wire worn through, shorting it out causing a fuse to blow all the time.
blowing fuses
Post by a team on Tue Feb 23, 2016 11:14 pm
thanks for replies guys ive sussed it it was indicator shorting.thanks
a team
Re: Blowing fuses
