fuel return line
fuel return line
Post by conla on Mon Jan 18, 2016 8:20 pm
hello everyone,
seems that no one in here could tell me where my headlight relay is located... so here is another one
the fuel return line on my fuel tank is shooting out gas (yes from the tank) what should I look for to solve this problem
conla
Re: fuel return line
Post by HighlyJetted on Mon Jan 18, 2016 8:28 pm
Corroded metal pipes on the top of the tank are common. Pretty much all the metal fuel pipe work is prone to corrosion.
I tend to bypass it all with flexible rubber high pressure fuel hose.
