4x4 front brake disc replacment
Post by jbenny2 on Sun Feb 21, 2016 9:07 am
Hi all, i've just tried to change the front brake discs on my 4x4 hi jet and the disc seems to be held on behind the hub carrier meaning you've got the take the hub nut off. Mines not a castle nut and split pin but one with the silly little tabs that you tab over to lock it. is the 4x4 the same as the standard front hub nut torque setting when doing back up ?
jbenny2
