Temp gauge reading hot when engine cold and erratic throttle
Post by jbenny2 on Thu Mar 03, 2016 7:59 pm
Hi all, just booked my 1.3 efi porter in for it's mot and when i got home the misses told me the throttle was revving up and down in traffic and then returns to normal, then starts again a few miles later. I popped out to check it, started it and noticed the temp gauge reading all the way to the hot (normally only sits in the middle), so i put the heater on full to cool it down and it blew cold air out the screen vents Shocked I asked the wife and she said she had been home for hours so the van was stone cold. So i thought it could be a faulty temp sensor but could this be causing the erratic reving, if it's sending false info to the ecu ?? Any help as I'm completely stumped.
jbenny2
Re: Temp gauge reading hot when engine cold and erratic throttle
Post by HighlyJetted on Thu Mar 03, 2016 9:13 pm
They hunt like that if the fast idle valve is open.
The fast idle valve stays open if there is no coolant in it.
And three guesses why there is no coolant in it!
Good luck
Post by jbenny2 on Thu Mar 03, 2016 10:03 pm
I can try and bleed the air out of the systems but it gets changed every 2 years and filled back up again by the approved method and no problems what so ever up until now. That whats made me think it could be a faulty temp sensor telling the ecu to alter the engine rpm? Was only a thought i will see if i can get the temp sensor off the rad pipe, its a bugger as it's just above the front diff so no access from below, unless it's not in the rad pipe and on the block somewhere?
jbenny2
Post by HighlyJetted on Thu Mar 03, 2016 10:12 pm
That isn't the temperature sensor in the pipe. Thats the fan switch.
Post by wrightgeordie on Sat Mar 05, 2016 9:23 am
I've been trying to find a coolant temperature sensor for my Hijet, if yours is the same type I hope you have better luck than me in finding a new one.
wrightgeordie
Post by jbenny2 on Thu Mar 10, 2016 4:21 pm
no it appears to be low on coolant i topped it up following the destructions behind the front grill and all is well again. phew! Cool
jbenny2
Post by HighlyJetted on Thu Mar 10, 2016 10:42 pm
Ask yourself where did the coolant go.
Post by jbenny2 on Sun Mar 13, 2016 9:07 am
I'm a little worried as i can't see any obvious leaks under the car, but it's been raining a lot lately so not always obvious. I'll be keeping a close eye on the oil for milkiness in case of head gasket failure, but I've had one go in the past where the water way leaked into a piston so the oil was fine but loads of water out the exhaust. Watch this space
jbenny2
Post by HighlyJetted on Sun Mar 13, 2016 11:08 am
You don't get oil/water contamination on most modern engines since like the 1980's.
Its one of those things I hear everyday, and I just want them to stop repeating it, keeping the myth alive.
