Track rod ends tie rod ends different types
Post by jbenny2 on Thu Mar 10, 2016 4:47 pm
My van has failed the MOT on a broken sliding door handle (this is a long story but getting it sorted), and track rod end. I've ordered 2 sets of Quinton Hazel track rod ends and both are with a female thread and mine needs the male thread. I've rung up about 15 companies asking if they can either send me a photo or confirm if the thread is male or female and all they say is give me the vehicle reg and we'll check Mad I've been down this road twice and have 4 brand new incorrect track rod ends on my dining room table.
Does anyone know if the part numbers QR5307S and QR5308S are correct for the male threaded ones. Any help really appreciated as the wife has no transport at the moment and i need to get it back on the road ASAP.
jbenny2
Re: Track rod ends tie rod ends different types
Post by jbenny2 on Thu Mar 10, 2016 4:57 pm
jbenny2
Post by PFM on Thu Mar 10, 2016 9:26 pm
I had this problem too some years back. I thought I'd made a note of part No.s at the time, but can't find it. There's a page on Amazon showing male thread on a QR5308S, and eurocarparts show male threads on these 2 pages:
http://www.eurocarparts.com/ecp/c/Daihatsu_Hijet_1.0_1995/p/car-parts/steering/suspension-and-steering/track-rod-and-track-rod-end/?60656027J&1&61ce480398049d38bc9583d8a2eb3e4847a18eaa&000349
http://www.eurocarparts.com/ecp/c/Daihatsu_Hijet_1.0_1995/p/car-parts/steering/suspension-and-steering/track-rod-and-track-rod-end/?60656028J&1&4f2fe12b8b0f6e4c97d873f8f35d12ea2a098125&000349
They suggest a 6-week wait but phoning your local branch may help. Just be aware that illustrations in parts catalogues may not always be accurate, but you should be able to return the item if the picture is part of the description and doesn't state 'library photo' or similar. The Blueprint cataloge doesn't list T/R/E's for Hijets as far as I can see.
Post by HighlyJetted on Thu Mar 10, 2016 10:50 pm
I think QR5308S has an external thread.
While QR5307S is a cast unit with a drilled and threaded hole.
But don't blame me if I'm wrong!!
Post by jbenny2 on Sun Mar 13, 2016 9:03 am
Thanks guy's i've ordered both and figures crossed one of them is correct !
jbenny2
Post by HighlyJetted on Sun Mar 13, 2016 11:08 am
Thats my kind of strategy Smile
Post by wrightgeordie on Wed Mar 16, 2016 1:08 pm
Just arrived today for my 2002 Van, Quinton Hazell Ball Joints
Part No QR5308S RH thread and QR5307S has a LH thread
wrightgeordie
Post by PFM on Wed Mar 16, 2016 1:20 pm
But are they the correct sex?
Post by wrightgeordie on Wed Mar 16, 2016 1:28 pm
Very much of the male gender.
wrightgeordie
Post by HighlyJetted on Wed Mar 16, 2016 1:44 pm
Can you photo each part number and ball joint with accurate information regarding threads and gender.
Post by buttondup on Sat Oct 01, 2016 5:30 pm
I'm having to replace the whole set of tie rod ends and as far as I can make out, 2 of each of the aforementioned part numbers makes a complete set - each number can be used for the outer and the inner on the opposite side, ie drivers side outer & passengers side inner. Please correct me if i'm wrong.
I need to replace the tie-rod also (some eejit Jack the lad thought it would be fun to play banger racing as I was turning into an acute right junction and it buckled into a banana shape) so if anyone can help me out on this or knows of a supplier it would be much appreciated.
buttondup
Post by Woodie on Sun Oct 02, 2016 11:35 am
Before you buy a Track Control Arm, measure the length of the Tie Bar from the end of the thread to the end of the rod where it is welded to the arm.
From memory it 24" as last year members were buying them and finding out that the Tie Rod supplied was 26" long.
Post by buttondup on Sun Oct 02, 2016 1:21 pm
ok, thanks Woodie
buttondup
