Bollox!!!!!!!!!!!
Bollox!!!!!!!!!!!
Post by Logi on Tue Mar 15, 2016 7:29 pm
Sootyvan has only gone and popped a bloody wheel cylinder Sad
Ok, those in the know, as I've had sfa to do with the rear brakes, how do you get the shoes off? Do you need to pukl the half shaft? It's a gooey mess in there, and I'm having to do it on the drive as the Merc is in the garage. Crying or Very sad
Re: Bollox!!!!!!!!!!!
Post by HighlyJetted on Tue Mar 15, 2016 10:30 pm
Just take drum off - it has threaded holes to use an old bolt to pop it off the hub.
Then shoes come off by taking the retainer springs, and the two little twist retainers which hold them to the backing plate.
Then clamp the flexi down to the rear axle.
Heat the flare nuts up with a blow torch. Undo them without fucking the pipe.
Fit new one.
Rebuild, and bleed up while keeping the LSPV in the upwards position so its pushing on the valve, using the pedal press method or whatever.
Cheap as chips the rear slave cylinder, very very very common failure.
Post by Logi on Wed Mar 16, 2016 6:54 pm
The issue is with the shoes, drums off, cylinder's changed, can't get the f"ckin shoes back on due to the handbrake mech, wont fit past the wheel cylinder and can't get the bassa to fit in the wee slot for the auto adjuster when in position.
I'm due to punch the shit out of it soon. Mad
Post by HighlyJetted on Wed Mar 16, 2016 7:09 pm
It does fit, I've done it loads of times. User error!
Post by Logi on Wed Mar 16, 2016 7:11 pm
Probably Embarassed
Post by HighlyJetted on Wed Mar 16, 2016 7:19 pm
Hardest thing is getting the springs back in.
Post by GEORDIE on Thu Mar 17, 2016 12:24 am
Bit of string/cord round the hooked end of the
spring then pull
GEORDIE
Post by Logi on Thu Mar 17, 2016 6:19 pm
GEORDIE wrote:Bit of string/cord round the hooked end of the
spring then pull
Post by GEORDIE on Thu Mar 17, 2016 8:08 pm
with out your wit Logi where would we be
GEORDIE
Post by HighlyJetted on Thu Mar 17, 2016 9:04 pm
Stood around that noose waiting for one of us to go first?
Post by Logi on Sat Mar 19, 2016 8:54 am
Well, that's that fixed, found an easier option, gave ir to a friend who has a garage and they fixed it Smile
Just couldn't be arsed with fannying about with it any more. Best bottle of whisky I've parted with in a while.
Post by GEORDIE on Mon Mar 21, 2016 3:18 pm
Know the feeling Logi,just had to part with £40 to
get front left wheel removed-was stuck on the hub
and you can't swing the the big hammer laying on
the back!!
GEORDIE
Post by HighlyJetted on Mon Mar 21, 2016 4:55 pm
These old timers are just full of sh1t excuses.
Post by Logi on Mon Mar 21, 2016 9:27 pm
HighlyJetted wrote:These old timers are just full of sh1t excuses.
Twisted Evil
